Hello Guest it is October 22, 2026, 03:59:49 PM
Author Topic: opening an m1s file  (Read 13207 times)
opening an m1s file
« on: April 28, 2012, 08:24:17 AM »
Hello Jimpinder--
I am trying to figger out macros and I came across some replies of your which included
the following files
m202.m1s
1024.lset
m201.m1s
Please tell me how to open and use these files
Many thanks
fred evans
Re: opening an m1s file
« Reply #1 on: April 28, 2012, 05:33:50 PM »
Hmm....haven't heard from Jimpinder in some time........
- 1024.lset is a standard "screen set" for the lathe ulness Jimpinder modified one with the same number  ???
- m202 & m201.m1s are macros and can be called from within a program file or via the MDI line.
On the top of the screen select Operator> VB Script Editor then select the macro and you will be able to see the coding if so desired.
« Last Edit: April 28, 2012, 05:39:17 PM by RICH »
« Reply #2 on: April 29, 2012, 06:27:20 AM »
thanks rich-- will try it tomorrow at work
regards
fred
« Reply #3 on: April 29, 2012, 06:38:47 AM »
You can also open .m1s files in any text editor. Notepad, Worpad, Word, ....
