Hello Guest it is October 30, 2026, 10:36:50 AM
Author Topic: 2 steppers driving the Y axis  (Read 43913 times)
Offline TomR
  •  17 17
« on: April 21, 2012, 11:37:31 AM »
I am experiencing a racking problem on the Y axis gantry and looking for some ideas on how to correct this problem.  I am new to the blog (my first post) and assume this is a common problem which has been previously addressed.  Thus, sorry if I am kicking a dead horse.
Specifically, what I would like to do is have 2 stepper motors, each driving lead screws on either sides of the gantry.  Also I would like to have 2 homing switches such that when running a homing routine the gantry is squared to the X axis in the process.  I know Mach3 has a “slave” feature for such stepper configurations but not sure how this works or how to wire the motors and limit switches.
As background, the router has a table size of 24” square.  The hardware consists of Probotix boards (PBX-RF breakout, 3  Probostep VX drivers) and unipolar steppers.
Thanks in advance for your help.
Re: 2 steppers driving the Y axis
« Reply #1 on: April 21, 2012, 02:59:41 PM »
You'll need an additional drive for the second Y axis motor. Set up the additional motor as the A axis, and go to config > slaving and check the box to slave the A to the Y ( I think that's what you're saying). That's it. Both the Y and A axis should have their own home switch set up, and in General Config, make sure "Home Slave with Master" is NOT checked.
That's about it. Just make sure the A and Y axis have identical motor tuning and home speed settings.
Offline TomR
  •  17 17
« Reply #2 on: April 21, 2012, 05:18:07 PM »
Thanks for the quick reply.  I think I understand what you are saying but I'm sure I'll be back with additional questions once I purchase the hardware.
