Hello Guest it is October 22, 2026, 04:30:13 PM
Author Topic: Turn wizards?  (Read 9638 times)
Turn wizards?
« on: April 18, 2012, 08:11:36 AM »
Was messing around with the view tab and load screens on my Mach 3 turn installation and my turn wizards have gone, replaced with the mill wizards, Eek! can I get them back and if so, how, or do i have to reinstall Mach 3 turn?
Help!
Best regards,
Wayne
Re: Turn wizards?
« Reply #1 on: April 18, 2012, 08:18:41 AM »
Just do the  view, load screens again then in the file type drop down choose .lset and then you will see the available turn screensets, load one (standard is 1024.lset) and then you should be back in business :)
Re: Turn wizards?
« Reply #2 on: April 18, 2012, 12:35:06 PM »
Didn't work! did reinstall instead!
Wayne
Re: Turn wizards?
« Reply #3 on: April 18, 2012, 12:57:25 PM »
The only thing that differentiates a Turn profile from a Mill profile is the screenset type that is loaded. If you have a mill profile and load a .lset screenset then it will then use all the Turn wizards, axis movements etc. It may have been that you id not restart Mach after you loaded the .lset screenset, I should have mentioned that that would be needed, sorry.
