Hello Guest it is November 12, 2026, 12:09:44 AM
Author Topic: Plasma drive problem  (Read 9049 times)
« on: April 11, 2012, 03:50:25 AM »
Starting to tune my table and I ran into an odd thing.  I was setting up motor speed and other things and all was fine in mach 3 mill.  I though I should do the same in mach 3 plasma I checked the pins for motor control and set the same speed values in motor control and then turned on jog to check.  Well the X buttons moved the Z motor and Y motor was fine but Z buttons did nothing ( not able to move anything but the dro displayed movement).  I just moved from mill to plasma software and nothing else was changed.
All motor pins are the same in both software settings.
I am using ver 2.58.  have you seen this or heard of it???
Tom
Re: Plasma drive problem
« Reply #1 on: April 15, 2012, 05:15:18 PM »
Check your output enable pins had the same problem
« Reply #2 on: April 15, 2012, 10:22:02 PM »
Thanks for the reply I downloaded the next ver (3.043)of software and do not have the problem with either plasma or mill settings.
hav fun
Tom
