Hello Guest it is November 12, 2026, 04:08:33 AM
Author Topic: PART CNC PART MECHANICAL  (Read 103866 times)
Re: PART CNC PART MECHANICAL
« Reply #20 on: April 20, 2012, 01:31:06 PM »
Where should I connect the blue wire to on a TB6560 BOB?
Graham
« Reply #21 on: April 20, 2012, 02:25:31 PM »
Any spare input you have.
« Reply #22 on: April 21, 2012, 10:00:46 AM »
Hood--- Thanks
Any spare input you have? They all look the same to me except the obvious power supply and stepper motor wires, as I have said before I am no electonics expert only very basic wiring.
Graham
« Reply #23 on: April 21, 2012, 10:03:32 AM »
Do you have a manual as I am not familiar with that board.
« Reply #25 on: April 21, 2012, 10:20:47 AM »
Or better still
« Reply #26 on: April 21, 2012, 10:26:33 AM »
Ok look at the eBay auction, if thats the same one you have (there are many variations coming out of China) then you will see lower left corner it says 4 Inputs.
If you scroll further down you will see a representation of E-Stop etc connecting to these inputs. It tells you there which pin on the connector corresponds to the parallel port pin so for example pin 1 on the connector on the board connects to pin 10 in Mach, pin 2 to 11 etc. If you have a spare pin then you want to connect it into that then tell Mach which pin you have connected the index to.
« Reply #27 on: April 21, 2012, 04:01:28 PM »
More thanks, its getting clearer by the explanation off you, soon I will be screwcutting once I have the ball screws fitted and operational.
Graham (from sunny Devon)
« Reply #28 on: April 21, 2012, 04:23:28 PM »
No probs.
Threading on a cnc lathe is just so easy. I do a lot of threads and even if I am doing something on the manual lathe if there is a thread to be done I will pop it in the CNC and thread. I would never even consider doing a thread on the manual lathes nowadays.
« Reply #29 on: May 13, 2012, 01:22:19 PM »
Hi Hood
Thought it was too simple.
Exactly where do you get the 5 volt supply from as there are no obvious connections for it on the BOB TB 6560?
Will I have to get a seperate power supply if so what spec?
I have been given some 200 ohm resisters will two in series be OK as you specify 220ohms?
Graham
