Hello Guest it is October 20, 2026, 03:50:31 PM
Author Topic: Strange shift in Z-axis during machining  (Read 19839 times)
Offline Chet
  •  58 58
Re: Strange shift in Z-axis during machining
« Reply #10 on: April 06, 2012, 08:24:11 AM »
Once again, guys, thanks for the feedback.
The capacitors were installed awhile back.
And I think I'd rather live with a 'random event' than turn off the shop vac and have all that foam dust hitting the air...
Should the event happen again, I'll have to switch over the machine coordinates and see what the z-axis says...
Good thought, there...
« Reply #11 on: April 06, 2012, 12:29:58 PM »
Better doing a  verify if you have home switches unless of course you know what the offset is so you can work out what the machine coords should be at that point.
