Hello Guest it is November 23, 2026, 08:29:41 PM
Author Topic: Lost Steps Found  (Read 8468 times)
Offline SMA
  •  68 68
Lost Steps Found
« on: April 04, 2012, 10:56:03 AM »
Well after nearly a year of searching for lost steps, which of course took untold number of hours and frustration, I happened across this link http://www.candcnc.com/G251-4_FMK.html.
When testing my z axis one thing I did was write a simple file, as I discovered today is suggested, that would have the axis change direction multiple times.  When ran the file I discovered that with each direction change there was an equal amount of position loss.  I can't remember now but about 20 cycles of direction change on z would equal about 2mm of position loss.
Thought I should post in case there are others out there.  This isssue is likely an old one but always best not to assume.
S
Re: Lost Steps Found
« Reply #1 on: April 04, 2012, 04:56:51 PM »
Good to hear, hopefully you will be sorted once you get it done.
