Hello Guest it is November 22, 2026, 09:03:40 AM
Author Topic: Help on PMDX-125 & PMDX-107.  (Read 24259 times)
Offline Jackal
  •  173 173
Re: Help on PMDX-125 & PMDX-107.
« Reply #10 on: April 02, 2012, 03:45:37 PM »
Thanks Hood,
I'll look further into that.
Jackal :)
Everything is bio-degradable if you run over it enough with a lawnmower.
« Reply #11 on: November 21, 2013, 05:05:30 PM »
Hi Hood, it has been a while.
Once again I have tried to search the forums but not using the correct key words I come up with nothing.
I'm trying to setup my PMDX-125 to allow me to start and stop a dust extractor using the laser on/off button on the screen or a macro key on my wheel control unit. Could you please point me in the right direction. regards John
« Reply #12 on: November 22, 2013, 02:27:50 AM »
Can you attach your xml please.
Offline Jackal
  •  173 173
« Reply #13 on: November 22, 2013, 08:09:08 AM »
Libbit,
On the 125 board you  have some relays that you can use to  control the dust collector. You might need to set up a separate button or use a brain for it.
I found out the spindle problem was the version of Mach that I am running.  I will probably change it and do some sorting out when it gets slow.
Jackal
« Reply #14 on: November 22, 2013, 01:59:45 PM »
Hi Jackal, that I know but my problem is I would like to assign laser on/off button (which is on Big Blue's) screen to the J10 relay on the125 board. IOW when I toggle laser on/off it trigers the relay.
