Hello Guest it is October 02, 2026, 07:10:03 AM
Author Topic: Help sinking ! Breakout board testing  (Read 9469 times)
Offline otpco
  •  48 48
« on: March 15, 2012, 06:37:51 AM »
Hi all I am in need of some help . I have a CNC4PC Parallel port Interface board C1 .I need to test it . I have the 5 volt supplyes and the enable connected .I have a bunch of lights going . Does a light come on when its enabled ? I cant seam to get anything through the board .Is there any easy test ? The machine has been in storage for a while .It did work . it goes from this board to my Rutex 990 boards . I have this so I can run my digi speed 03 without cutting the parallel port cable .( I am old and those ity bitty wires give me the s--ts ) any ideas would be good thanks otpco
  •  9,374 9,374
Re: Help sinking ! Breakout board testing
« Reply #1 on: March 16, 2012, 11:33:35 AM »
Hi otpco,
It could be that your Mach configuration is incorrectly set up in Ports and Pins (port address : motor output pin numbers : active hi / low etc) also have you been through the Troubleshooting guide in the C1 documentation ??  http://cnc4pc.com/Tech_Docs/C1R10_1_USER_MANUAL.pdf
Offline otpco
  •  48 48
« Reply #2 on: March 16, 2012, 05:25:47 PM »
Yes thanks I think I have a board malfunction or opperator !! Trying to work what lights mean what ! thanks for your time still working on it
