Hello Guest it is November 12, 2026, 07:52:29 AM
Author Topic: GalilInit  (Read 35023 times)
Re: GalilInit
« Reply #10 on: March 15, 2012, 05:09:32 PM »
Hi Kenny
I agree will spare me lots of time but  had problem of double speed of slave axis when homing in mach . Is there any solution for  this problem at this moment
 btw I have very little experience with cnc  i am building may first mill witch is supposed to be finished in two months ,,,,,  if I can find solutions for gentry  and some more
Firuz
Offline kcrouch
  •  193 193
  • In way too deep!!!
Re: GalilInit
« Reply #11 on: March 15, 2012, 06:37:07 PM »
Were both axes tuned the same in Mach?
Having way too much fun! Something must surely be wrong.
Re: GalilInit
« Reply #12 on: March 16, 2012, 02:44:39 AM »
Tuning parameter in mach                              master=slave
Servos and encoder type                                 master=slave
%sp homing                                                  master=slave
Motor tuning parameter in galil                        master=slave
Home slave with master axis                           uncheck
Perform axis squaring                                     check
Offline kcrouch
  •  193 193
Re: GalilInit
« Reply #13 on: March 17, 2012, 12:52:44 PM »
After much discussion, I found that the slaved homing issue started with Mach3 a few releases back. I would suggest that you use an earlier release (sorry, don't knw which to recommend) until the issue is isolated and corrected. I wish that we could fix it in the plugin, but no joy at this time.
Kenny
Re: GalilInit
« Reply #14 on: March 19, 2012, 10:13:47 AM »
I have read that you are one of authors of galilplugin and  understand that there  are many problems to take care about , hope you can isolate and solve this  problem .
 Until then I will try                - earlier plugins
                                           - geared axis  squaring done in galil  ( we will use mpg to test )
can you tell where to find earlier plugins  and there user pdf
Firuz
Offline kcrouch
  •  193 193
Re: GalilInit
« Reply #15 on: March 19, 2012, 10:41:15 AM »
Its not an earlier plugin, but an earler version of Mach3 that you need to look for. That is what broke the gantry mode homing.
Kenny
