Hello Guest it is November 23, 2026, 06:09:01 PM
Author Topic: Mach 3 not recognizing g commands correctly  (Read 8470 times)
« on: March 11, 2012, 09:53:57 AM »
Hi all new to this not sure what my problem is if i issue a g0 x5.0 command the axis will move but then if i issue a g0 x-5.0 the machine will move but in the same direction the same is true in the y and z axis what settings do i have screwed up thanks for ur help
  •  9,378 9,378
Re: Mach 3 not recognizing g commands correctly
« Reply #1 on: March 11, 2012, 12:22:25 PM »
Hi gtonini,
How does it behave when jogging from the keyboard - do all the axis move in both directions OK ??
« Reply #2 on: March 11, 2012, 12:24:33 PM »
Yes it does
« Reply #3 on: April 27, 2012, 12:57:43 PM »
I am having somewhat the same problem.
Jogging from keyboard works fine, but
Mach 3 ignores some gcode commmands ,but not others. It will ignore
G1 x-1
and run the next line-
G1 y3
seemingly picking the lines to run at random
it also draws lines on the computer screen incorrectly, leaving out the ones which are ignored when running the machine.
The machine was working properly last week.
What have I done,  or do I have to reload a new copy of the program
