Hello
Guest
it is
November 13, 2026, 01:54:54 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Lathe feed errors due to timing pulley runout
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Lathe feed errors due to timing pulley runout (Read 21923 times)
JohnHaine
975
Re: Lathe feed errors due to timing pulley runout
Reply #10 on:
March 23, 2012, 09:59:30 AM »
Just an update here. I have now rebuilt the cross slide drive with direct coupling of the motor to the leadscrew and things look much better, so I hope I'm back in business. Thanks for all the input.
John.
Logged
otpco
48
Reply #11 on:
March 24, 2012, 06:09:23 AM »
how good is the Myford bed .Is it worn .Myfords have a habit of shying away from work with there flat bed design . I used to have one and found that a couple of zero cuts helps . I now run Hercus/Southbend . And find heaps better . give it a go
Logged
JohnHaine
975
Reply #12 on:
March 26, 2012, 10:48:37 AM »
I got the lathe new and it hasn't had much wear. It was cutting undersize, not oversize, so zero cuts wouldn't help? But thanks for the suggestion, another thing to look at if still dodgy.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
