Hello
Guest
it is
October 12, 2026, 09:45:00 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
acceleration question
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: acceleration question (Read 11828 times)
studysession
176
on:
February 27, 2012, 07:40:50 PM »
Hi there -
I have my machine set and on most part everything runs pretty well but I sometimes lose steps on X-axis.
Q. If I slow down my acceleration, do I need to change any other settings or will everything else be ok?
Keith
Logged
http://celticmachining.blogspot.com/
Carnoustie, Scotland
Re: acceleration question
Reply #1 on:
February 28, 2012, 02:54:01 AM »
You wont need to change anything else, worth noting however, reducing the Velocity may also work and having a slower rapid with a faster acceleration is better than the other way around.
Logged
studysession
176
Reply #2 on:
February 28, 2012, 03:57:36 PM »
Thanks Hood! I will try that next I am home.
Logged
studysession
176
Reply #3 on:
February 28, 2012, 05:04:48 PM »
Hood -
How do I know when to adjust acceleration vice velocity?
Thanks -
Keith
Logged
Reply #4 on:
February 28, 2012, 05:33:26 PM »
With steppers everything is trial and error really. What I can do is give you an example. My Bridgeport had steppers and I had rapid set to 2500mm/min and the most I could get on accel without losing steps was 40mm/s/s. I reduced the Velocity to I think 2200mm/min and I was then able to increase the velocity to 120mm/s/s without losing steps. That made a huge difference to the machine as even though rapids were slower machining speed increased as it got to commanded speed much faster and especially where lots of small moves were being commanded.
Logged
studysession
176
Reply #5 on:
February 28, 2012, 05:45:28 PM »
Thanks! Hood - once again to my rescue!
Logged
Print
Pages:
1
Go Up
« previous
next »
