Hello Guest it is November 13, 2026, 01:52:52 PM
Author Topic: still miffied  (Read 20345 times)
Re: still miffied
« Reply #10 on: February 26, 2012, 02:58:12 PM »
ok hood here is my xml
Re: still miffied
« Reply #11 on: February 26, 2012, 03:09:18 PM »
Ok you have your native units set as metric which is what I presume you want but in motor tuning I would say your steps per unit are set to Inch as they are very high. If you divide the Steps per unit by 25.4 and multiply the Velocity and Acceleration by 25.4 you should be there. Assuming that is you calculated them correctly for inch.
