Hello
Guest
it is
November 22, 2026, 06:45:55 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Help / Advice on Power Supply for Series 1 Interact 1 Conversion
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Help / Advice on Power Supply for Series 1 Interact 1 Conversion (Read 22197 times)
alcwell
37
Re: Help / Advice on Power Supply for Series 1 Interact 1 Conversion
Reply #10 on:
February 09, 2012, 08:03:58 AM »
Thanks for the help Hood.
I will try the original transformer and see how it goes while setting up and testing.
If it works well all is good, if not I can come back to it.
Alastair
Logged
Carnoustie, Scotland
Reply #11 on:
February 09, 2012, 09:02:53 AM »
You will likely need more capacitance than the original had, maybe not, but the few I have seen have less than the 1000-2000uF per amp that seems to be standard to keep ripple low.
Logged
alcwell
37
Reply #12 on:
February 09, 2012, 04:02:52 PM »
Yes it will definitely need some capacitance added as there currently isn’t any! Or at least none that is external to the drives.
The 180VAC from the transformer is fed directly to the drives, each drive also has an external choke coil.
Alastair
Logged
Reply #13 on:
February 09, 2012, 04:24:27 PM »
Ah ok, thats the best way if the drives handle it but sadly none of the type normally used with Mach do. The AC servo drives I use take mains right in but suppose thats why there is a big difference in prices, well one of the reasons.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
