Hello Guest it is November 22, 2026, 06:54:28 AM
Author Topic: Plasma Z axis raises when torch is fired  (Read 31399 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Plasma Z axis raises when torch is fired
« Reply #10 on: February 10, 2012, 04:55:36 AM »
Just one problem....
If we (you  ;D) are not going to sort out peoples BOBs, SSs (other external motion cards are available), drives, motors, VFDs, spindles, tool-changers, power supplies, probes, pendants, machines of all makes etc. etc.
This place is going to get a little quiet.
That's not to mention CADs, CAMs....
Ian
« Reply #11 on: February 10, 2012, 06:15:33 AM »
Its ok, its just yours I wont help out on ;D
Mainly because I know SFA about THC ;D
Offline stirling
  •  2,188 2,188
  • UK
« Reply #12 on: February 10, 2012, 06:35:48 AM »
Mainly? Something you want to get off your chest there ma wee toorie bunnet wearing friend?  ;D
« Reply #13 on: February 10, 2012, 06:38:30 AM »
lol you programmer types read too much into words, wrong syntax used by me I suspect ;D
Offline stirling
  •  2,188 2,188
  • UK
« Reply #14 on: February 10, 2012, 07:19:27 AM »
 ;D
Offline stirling
  •  2,188 2,188
  • UK
« Reply #15 on: February 10, 2012, 07:27:03 AM »
While working on this I found that my ARC OK light is on if I turn the torch on even if i have my plasma turned off.  I am using the dry arc ok contacts but was using a current transformer before.  Is there a way that this could be causing my problem?  Eather way is there something I have to do to change the input from the CT to the contacts.  I know it should not be on without the CT connected but it is.
This is certainly wrong - the ArcOK (as you know) should not come on unless the arc is ... well ... OK which it clearly can't be if the plasma's off. This is something I think you need to run by your supplier.
Ian
« Reply #16 on: February 10, 2012, 09:07:58 AM »
AH YEP, that would do it. IF your ArcOK signal is ON all the time the instant you issue a M3 then the thc sees very low voltage and attempts to raise the head. As the arc actually starts the voltage goes UP and the THC corrects the head back down to the proper volt level.
Ian do you have units in the field yet??? Finalized the com system ???
YOUS GUYS show nuff talk funny . Must be something to do with being on the east side of the pond.
« Last Edit: February 10, 2012, 09:13:41 AM by BR549 »
« Reply #17 on: February 10, 2012, 10:27:15 AM »
Thanks I will call CandCNC again hopefully they can help this time. >:(
Offline stirling
  •  2,188 2,188
  • UK
« Reply #18 on: February 14, 2012, 12:22:07 PM »
Hi Terry - sorry missed this post. Yes at long last they're "out there" - http://www.razordance.co.uk/THC.htm
Ian
« Reply #19 on: February 14, 2012, 12:58:15 PM »
NICE, were you able to work out a tip saver funtion. I see you use the Mach3 antidive.
Any plans for US distributor ??
Plans for a Decent hand pendant for plasma ?
