Hello Guest it is November 13, 2026, 10:01:51 AM
Author Topic: home switches  (Read 9202 times)
home switches
« on: January 03, 2012, 09:40:11 PM »
Hi I am a newbie with the cnc thing I am setting up my machine I have everything working until I tried setting up home/limit switches. I have 3 NC switches wired in series with one end (com) going to post 1 on my g540 which is pin 10 and the other going to my DC-. My ports and pins in mach3 are set set correctly but when I go to the diagnostic tab The m1 m2,m3 home leds do not light when I activate a switch. If I go back into port/pin-imput signals and unclick active low all the leds light up but are not effected when I activate a switch. I must be missing something But I am stuck Any ideas would help
Re: home switches
« Reply #1 on: January 04, 2012, 02:20:04 AM »
Do you have the port number entered for the limits? If you do attach your xml and I will check your config.
Re: home switches
« Reply #2 on: January 04, 2012, 09:22:47 AM »
Ok thanks for the reply OK I have rechecked everything but I will recheck again
