Hello
Guest
it is
November 26, 2026, 08:51:49 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 on Sherline - any way to fix screen font in buttons ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 on Sherline - any way to fix screen font in buttons ? (Read 8541 times)
mach3ds
1
on:
January 01, 2012, 07:51:28 PM »
I just got Mach3 running for my Sherline mill with the Sherline driver box and I noticed that there is a row of buttons on one of the Mach3 windows that mostly have single line of text inside them. But one of the buttons has two lines of text "Normal Condition" in green that is squashed into the height of a single line of text making it fairly illegible. I tried changing the screen resolution to see if I could make this any better but to no avail. Is there some way to tweak these button heights in a screen settings file for example so these have some sort of normal text like MS Arial Narrow bold or other instead of the squishy fat font used as default in the screen setup ?
Don Shaffer
Logged
ger21
6,295
Re: Mach3 on Sherline - any way to fix screen font in buttons ?
Reply #1 on:
January 01, 2012, 08:44:38 PM »
The button in question is an image file that is too tall to fit the button. If you re-create it in an imaging program at half the height, it should look much better.
Logged
Print
Pages:
1
Go Up
« previous
next »
