Hello Guest it is October 21, 2026, 02:27:37 AM
Author Topic: Sometimes it's the quick and easy ones......  (Read 29959 times)
Re: Sometimes it's the quick and easy ones......
« Reply #10 on: December 29, 2011, 07:23:39 AM »
Hi Dave
Looks very nice.
Typically what sort of depth have you achieved and was it done in a single pass?
Thanks Brian
« Reply #11 on: December 30, 2011, 06:48:19 AM »
Hi Brian,
Thank you for the kind words. While I haven't actually checked with an indicator, it seems I get about .010" depth with 2 passes in 6061 aluminum and probably about .005-.006" in engravers brass. The pendulum was a bit more as it's very thin, and easily manipulated as it's hollow, not solid. 2 passes are better as the first pass sometimes gives "hair-like" burrs that seem to be eliminated on the second dry run pass.
