Hello Guest it is October 23, 2026, 08:04:50 PM
Author Topic: Mach3 and THC Problem  (Read 37425 times)
Re: Mach3 and THC Problem
« Reply #10 on: November 08, 2013, 07:17:28 PM »
Hey guys
I got the same problem but, I have actually seen the ARC OK - TORCH ON signal on mach3. It appears when the sensor ring tourch the plate ("touch" on thc leds). I should appear when is in probe ("in position" on thc leds).
I read that you solved the problem with a relay, well, it can work to me too, bur i think is more cheaper an proper to put that signal on the right position, any suggestions??  Have you heard somebody that can solve this without the relay?
Thanks a lot.
