Hello Guest it is November 19, 2026, 07:49:18 AM
Author Topic: g92 Proper Use Of with M98, M99 ?  (Read 32599 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: g92 Proper Use Of with M98, M99 ?
« Reply #10 on: December 24, 2006, 07:37:36 PM »
Hi, Graham
I read up on G52 code will try it some hear.
Thanks for the help.
I see its late there.
Chip
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #11 on: December 24, 2006, 08:30:15 PM »
Hi Chip,
I have just played about with the program and it is looking like its Machs drawing of the run path that is at fault, if you run the program offline and watch the figures in the machine dro's the offsets are being applied and canceled as they should be but the screen is drawn with the local dro figures without the offsets.
Try the included program.
Graham.
Offline Chip
  •  2,055 2,055
« Reply #12 on: December 24, 2006, 10:25:56 PM »
Hi, Graham
Yes I agree NCPlot simulates both filers, just fine hear.
Switching between ABS and Machine Coord's, They are not in agreement with the Screen View with the Second Part.
Maybe this is part of the problem with Feed-Hold, Re-Start and restart after jogging problems.
Just a Bug Hunter Hear, trying to scrape myself to the top of the Heap.
Thanks, Chip
« Last Edit: December 24, 2006, 10:44:36 PM by afn09556 »
« Reply #13 on: December 25, 2006, 07:52:31 AM »
G52 is a much better way to go :)
In the Fanuc's you can't have both G92 and Fixture offsets at the same time... So please stick to the Offsets and all will be good ;)
www.newfangledsolutions.com
www.machsupport.com
Offline Chip
  •  2,055 2,055
« Reply #14 on: December 25, 2006, 08:42:37 AM »
Hi, Brian
Its more of a screen issue, Mach draws it fine just doesn't follow screen path, Doesn't Mach use the Screen.Data-File.
Shouldn't Mach follow Drawn Path.
Thanks, Chip
« Reply #15 on: December 31, 2006, 08:30:31 AM »
Chip it is very hard to try to follow the path of the something that can change it's zero at will :(
Post an example program and I will see what we can do
Brian
www.machsupport.com
