Hello Guest it is October 25, 2026, 01:35:49 AM
Author Topic: Machine jumps when in program and looking at last wizard  (Read 84342 times)
Re: Machine jumps when in program and looking at last wizard
« Reply #30 on: December 20, 2011, 03:54:06 AM »
Well, Ray, since you keep feeling the need to go on, I keep feeling the need to help you  ;)
There are a couple of screen designers just for this situation, that I bet if you were willing to look at, with your obvious intelligence, you'd figure it out in an hour and have that button removed in no time at all. Just make sure you make a backup of the screenset before playing around.
This is the whole point of Mach. It's cutomizable to the user, and the way they like to use Mach 3. Don't like a feature? Just remove it from the screen. Want a feature from another page, but it's not on your preferred screen? Just add it, and away you go, it's that easy.
Hope that helps-
Offline dresda
  •  220 220
« Reply #31 on: December 20, 2011, 06:15:43 PM »
Thanks Dave. For now I will leave it, not a problem for me using it, and you are right and that's what I like about it.
Ray.
