Hello Guest it is November 03, 2026, 05:24:59 AM
Author Topic: Sherline Mode kills Output#1 - why??  (Read 10337 times)
« on: November 29, 2011, 10:45:38 AM »
I'm having missed steps problems, and want to try Sherline mode.
When I enable Sherline, Output#1 (which is my coolant) ceases to function - the physical pin is always stuck low (.063v).  Mach's Diagnostic page shows Output1 toggling properly, even though the physical pin is not.
When I disable Sherline, the physical pin toggles fine.
Output#1 is the only output I use (other than Motor pins, which seem fine); I didn't try the other outputs.
Any ideas ?
Using Mach 03.043.053
Re: Sherline Mode kills Output#1 - why??
« Reply #1 on: November 29, 2011, 02:26:36 PM »
Have you tried the lockdown instead of the development version?
« Reply #2 on: November 29, 2011, 02:52:17 PM »
No.  My original goal was fixing my suspected missed steps, and the siren call of the "updated parallel port driver" in the development version was too tempting to ignore.  Is it worth going back?
I've bit bullet and ordered a smoothstepper.
« Reply #3 on: November 29, 2011, 05:01:20 PM »
Probably best to at least try
