Hello Guest it is October 25, 2026, 07:34:32 AM
Author Topic: Black Friday in my CNC world  (Read 24606 times)
Re: Black Friday in my CNC world
« Reply #10 on: November 25, 2011, 02:26:42 PM »
In General Config, check "Persistent DRO's" in the lower right corner
« Reply #11 on: November 25, 2011, 04:14:29 PM »
I have done that but it still doesn't retain the setting.
« Reply #12 on: November 25, 2011, 06:44:27 PM »
Do you have optional offset save checked in general config as well? If so you should get a popup when closeing Mach asking if you want to save current offset.
« Reply #13 on: November 25, 2011, 09:02:24 PM »
Optional offset save is checked. However, when exiting program values default to X +1.0904, Y-.3159, Z-2666.
It doesn't matter if I say Yes to Fixture Save or No.
Then I have to Reset X,Y,Z back to 0 every time.
« Reply #14 on: November 26, 2011, 06:09:58 AM »
If it's not at 0,0,0 when you exit Mach3, it won't be at 0,0,0 when you restart it. If you're zeroing X and Y any time while using MAch3, you're setting a G54 offset, which will be in effect when you restart Mach3.
Sounds like you may want to uncheck all those boxes in the lower right corner?
« Reply #15 on: November 26, 2011, 06:42:44 AM »
It was at 0,0,0 when I exited but when I returned it was always different.
Unchecking those boxes retains 0,0,0.
You are correct, thank you.
