Hello Guest it is November 13, 2026, 11:49:26 AM
Author Topic: Limit/Home Switch setup question  (Read 20168 times)
Re: Limit/Home Switch setup question
« Reply #10 on: November 25, 2011, 03:48:37 AM »
Hi
I have been working on this with my friends setup.
Firstly, as the post says above, same pins as your x,y,z, ( on his 11,12,13 )
Secondly, ( important ) make sure your direction of travel for that axis is set up the right way,  If its reversed in ports and pins, reverse it in home/limits setting.  ( if not it will try run off the end of the table still )
And finally, ( our problem was this ),   cheep Chinese cables absorb interference better than my children absorb cash ( and that takes some beating ) .    So make sure your cables are clear of your power and spindle cables ect.
