Hello Guest it is November 22, 2026, 02:28:13 PM
Author Topic: Is it possible to call an external gcode file from within a gcode file?  (Read 9003 times)
I am trying learn if it is possible to call an external Gcode file from within a Gcode file that is running.  What I am trying to do is be able to make a macro from a pattern repeating file that will call up the external pattern and repeat it the number of times entered into Gcode.
Larry
Re: Is it possible to call an external gcode file from within a gcode file?
« Reply #1 on: November 17, 2011, 07:15:04 PM »
Yes it is called a SUB. You store the SUB in the SUB directory and call it with the M98 sub call in the Gcode program.
You can find more info in the Mach3 manual.
« Reply #2 on: November 20, 2011, 07:26:19 AM »
Great, Thanks
Larry
