Hello Guest it is November 22, 2026, 06:29:52 PM
Author Topic: Motors not working  (Read 34556 times)
Offline Claus
  •  14 14
Re: Motors not working
« Reply #10 on: November 11, 2011, 04:37:38 PM »
i have written 1 in all 6 colums but it still dosent work.
All parts are bought at Marchant Dice UK
Seller send me this PDF file ( please check)
i have tried set up 5 times on 2 diff PC incl what was missing now.
So it is very strange, i have been told that when the motors are on, they make a kind of noise, but until now they are dead silent.
« Reply #11 on: November 11, 2011, 04:48:47 PM »
Looks to be right with your xml. If you have a voltmeter you can check the Dir pins of each axis to see if they are getting 5v or 0v depending on the dir you jog that axis.
Offline Claus
  •  14 14
« Reply #12 on: November 11, 2011, 04:52:54 PM »
Thanks i´ll get a voltmeter tomorrow ( i dont have one)
and se it there is any voltage output on the cable.
Claus
« Reply #13 on: November 11, 2011, 04:54:21 PM »
Remember it is the port pins you are checking so check either on the computer with the cable unplugged from the port or at the board end of the cable.
Offline Claus
  •  14 14
« Reply #14 on: November 12, 2011, 01:13:38 PM »
Hi Hood
I havent cheked the pins yet ( an electrician is comming over sunday)
although i think there is connection from the PS to th board.
When i turn on the PC, 3 small red led lights on the board are "on" ( powersupply to the board are not connected at this point)
so the board gets some power from the PC.
When i start MAch 3 the 3 lights goes out !!!
Maybe they are suppose to, or maybe not
What do you think ?
Claus
« Reply #15 on: November 12, 2011, 01:43:41 PM »
Do you know what the LEDs are for?
Offline Claus
  •  14 14
« Reply #16 on: November 12, 2011, 01:51:38 PM »
No .  the board are a Toshiba TB6560
i am trying to find a manual where it is described .
« Reply #17 on: November 12, 2011, 02:03:38 PM »
Dont know much about the TB boards I am afraid.
  •  9,378 9,378
« Reply #18 on: November 13, 2011, 07:19:39 AM »
Claus,
Just a thought but try configuring Mach / Ports & Pins / Motor Outputs as shown below. ( not sure why Mr Marchant gave you those pin numbers in the pdf ).
  •  9,378 9,378
« Reply #19 on: November 13, 2011, 07:29:49 AM »
Another point I forgot to mention.
The pdf does not show an EARTH connection to the power supply incoming mains terminal block - this is incorrect, the power supply is technically class 1 insulated equipment and must be earthed (EU countries).
« Last Edit: November 13, 2011, 07:31:23 AM by Tweakie.CNC »
