Third party software and hardware support forums. > Newfangled Solutions Mach3 Wizards
NFS Turn Wizard
RICH:
Ron,
Nice addition.
Just did a quick look and didn't try all of the operations so no comments.
What version of Mach should one be using with the wizard?
Ron Ginger:
--- Quote ---What version of Mach should one be using with the wizard?
--- End quote ---
I think it should work with just about any version. I originally used some of the new scripting features, like #Expand, but I took all that out just do I wouldnt be version dependent. It makes support a bit harder, but gets out of the version problem.
Overloaded:
Hi Ron, looks real nice.
Will you be adding different feeds and depths of cut for roughing and finish cuts ?
Russ
Hood:
Looks great Ron, will just go try it out now :)
Ron Ginger:
--- Quote ---Hi Ron, looks real nice.
Russ
--- End quote ---
I want to keep the screens simple, so I didnt add rough and finish cuts. You could do that by just specifying 2 operations, the first to stop short of the final dimension, the second to be the finish cut.
However, I associated feed with the tool, so to change the feed you would need to do another tool operation.
I may have to re-think that. Ill listen to some more feedback and decide what to do.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
