Hello Guest it is November 13, 2026, 09:34:37 AM
Author Topic: Wire gauge  (Read 12004 times)
Offline lew
  •  74 74
Wire gauge
« on: December 20, 2006, 02:00:35 PM »
Another question.
I'm using Gecko's and Mach3. Just now building the system.
Wondering what recommendations for wire size?
I'm using 12awg. from the torroid to the capacitors but don't think I need or can use this size for power to the gecko's and out to the stepper's.
What should I be using from the gecko's to the steppers and what should be used from the power supply to the power and ground on the gecko's?
Thanks in advance.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Wire gauge
« Reply #1 on: December 20, 2006, 05:58:49 PM »
As long as you know the voltage and the maximum power required you can work out the cable size.
formula :- watts/volts = amps
So 1000/240=4.16 Amps
Or 1000/120=8.33 Amps
16 AWG will take approx 15 Amps
21 AWG will take approx 2.5 Amps
All you need to do is pick a cable of this rating or higher.
The table gives a guide as to the AWG to MM2 conversion
Graham.
« Last Edit: December 20, 2006, 06:31:39 PM by Graham Waterworth »
Re: Wire gauge
« Reply #2 on: December 20, 2006, 06:30:03 PM »
Good job Graham! Ohms laws anyone?  ;D
Offline lew
  •  74 74
Re: Wire gauge
« Reply #3 on: December 20, 2006, 07:18:25 PM »
Thanks a bunch for the information.
