Hello Guest it is October 13, 2026, 02:51:20 PM
Author Topic: Help with Motor Tuning  (Read 10276 times)
« on: October 11, 2011, 02:11:42 PM »
Help
My K2 2514 mill is as follows:
3 - axis X,Y,Z
X - Kelig K23H286 425 oz-in
Y - same
Z - Kelig K23H276 282 oz-in
All 3 wired Bipolar (parallel)
Lead screw on all 3 axis 10 TPI
Using Kelig KL5042 Drivers on each motor
MACH3 set to 25000 kernel speed
I have set the micro-stepping to 1/8 which means
1600 turns/rev
In MACH3 - Motor Tuning - I have set the steps per
to 16000
Problem is when I send a command to travel 1" in
any direction, it only moves .2"
Any help would be appreciated.
Octavio
Re: Help with Motor Tuning
« Reply #1 on: October 11, 2011, 06:09:10 PM »
Sounds like you have metric and imperial modes mixed up somewhere.
« Reply #2 on: October 11, 2011, 10:41:24 PM »
When I reset my micro steps i had to reset my StepPerMinute setting in the setup page. I'm guessing this is your problem.
Regards, tonyNZ
« Reply #3 on: October 13, 2011, 05:16:06 AM »
Thank you both for your attempts to help -
But it was the dumbass operators fault - me.
It appears that the DIP switch for the micro steps is opposite
logic - up is off - down is on.
All is well now.
