Hello Guest it is November 13, 2026, 08:08:21 PM
Author Topic: gecko540 problem under mach3  (Read 96661 times)
Re: gecko540 problem under mach3
« Reply #20 on: October 09, 2011, 06:09:35 PM »
komar1970,
This problem is not only with this machine, it was with every my machine
You have numerous machines and computers. Can't tell if you ever realy resolved  any of the posted problems you are having. Some of the threads seem like they never come to a conclusion. I am not sure which machine or computer you are using at any given moment. One would think that after ONE YEAR
you would know how to set the steps per unit, be able to confirm the steps, set backlash ( backlash dosen't go away or get better), and understand if you deviate from the calculated how that relates to axis travel. Sorry if this sounds harsh ....but can't help fix the door hinges when the door is swinging  back and forth.
So keep to one machine, computer, xml file used for the setup, the type of screws  ( are they rolled / precision ground / how supported / etc.).
Maybe I am missing something, ???
« Reply #21 on: October 09, 2011, 06:22:57 PM »
komar1970,
1.What computer are you using? Dose it have on-board graphics ( is it the Dell)?
2.What version of MACH?
3.What kernel speed?
4.Run the driver test and post a picture of what the graph looks like.
   How close are the PULSES PER SECOND to the kernel speed?
5.Post your xml file.
« Last Edit: October 09, 2011, 06:27:47 PM by RICH »
« Reply #22 on: October 09, 2011, 09:44:18 PM »
ok i will add video
« Reply #23 on: October 09, 2011, 10:24:17 PM »
Are you THAT confident that the problem can't possibly be in your machine, that you're willing to believe all those thousands of satisfied customers are basically idiots?
 write to you so. if you were trying for 3 years with 4 komutery , change a few machines. and on each machine problem ?! you say why did not you call to somebody? I called the gecko . Gecko at all times says that they have no idea how to set the gecko540 with  MACH3 . I called to MACH3 support! This guy from MACH3 logged in to my computer's  verifiability all , and nothing helped , He said only the MACH3 is well set , but I have been with the problem unsolved . I'm sorry that I offended someone, I had not thinks of that at sorry men
« Last Edit: October 09, 2011, 10:34:02 PM by komar1970 »
« Reply #24 on: October 09, 2011, 10:45:53 PM »
komar1970,
 I'm in shock. I never wrote the I do not know how to set the machine , I have a problem with prcision  of cutting  parts , people from MACH3 can not hellp me ,  gecko will not help, because hi says that has no idea how to set the gecko540 with MACH3 and refer you to the MACH3
« Reply #25 on: October 09, 2011, 10:53:25 PM »
Please explain what you mean by this:  "volts is ok, 3.5 for each 2,4,6,8"
What stepper motors are you using?
What kind of power supply are you using?  What voltage?  What current rating?
What current limit resistors are you using on the G540?
« Last Edit: October 09, 2011, 10:56:12 PM by HimyKabibble »
« Reply #26 on: October 09, 2011, 11:12:06 PM »
my setup
« Reply #27 on: October 09, 2011, 11:13:25 PM »
next
« Reply #28 on: October 09, 2011, 11:18:48 PM »
file from me gecko
« Reply #29 on: October 09, 2011, 11:33:07 PM »
NEMA 23   620oz
motor   is  current 3.5A
 inductance 6.4   beacuse I am set   the setp pulse to 5   and speede  to 450
 resistors is 3.5
power supply 350 48v
