Hello Guest it is November 22, 2026, 04:10:35 PM
Author Topic: Double check when measuring tool  (Read 11284 times)
« on: September 29, 2011, 12:31:06 AM »
I have my router setup to measure tools from a fixed switch. I'm trying to modify it to where it touches twice, compares the values, and let's me know if it's out more than .002 off, then I want a message box to pop up with the difference in it. I'm getting a syntax error, probably something simple...
Re: Double check when measuring tool
« Reply #1 on: September 29, 2011, 04:22:40 AM »
Not great at VB but think most of the syntax errors are because you have = > where likely it should just  be > with no =
Also  you have miissed out " at the end of the following
 MsgBox("Check switch - " & Zpos - ZposC & "measurement error)
Should be
 MsgBox("Check switch - " & Zpos - ZposC & "measurement error")
Then there is the CodeSingle, dont know what that is but Mach is not happy so presume it should just be Code rather than CodeSingle
I think you will likely have to put
While IsMoving()
Wend
after each movement command also.
« Reply #2 on: September 29, 2011, 04:58:40 AM »
For "greater than or equal to" the correct syntax is
not
« Reply #3 on: September 29, 2011, 09:36:58 AM »
Also has CodeSingle been released yet?
You also missed a couple of closing " around a statement or two.
« Reply #4 on: September 29, 2011, 12:45:17 PM »
Thanks guys! Works great now. The 'CodeSingle'...that's just the way the software came setup. I'm running an Industry Control MCB-1 and it uses a modified version of Mach, under the version it says R4.000.000 Test...anyway, I've attached the finished file with corrections if anyone else is interested in it.
« Reply #5 on: September 29, 2011, 01:10:29 PM »
YEP that won't run on a standard Mach ver.
