Hello Guest it is October 09, 2026, 02:53:26 AM
Author Topic: SmoothStepper - Anyone Else Seeing This?  (Read 21178 times)
Re: SmoothStepper - Anyone Else Seeing This?
« Reply #10 on: September 17, 2011, 11:09:27 PM »
Terry,
OK, I'll give it a try....
« Reply #11 on: September 21, 2011, 05:08:36 PM »
Well......  Got a new one today!  A short program, just 30 lines or so, peck drilling two holes.  If I set look-ahead to 1, it works perfectly.  If I set it to 20, it will, at some random point in the program, try to send the Z axis to the other side of the planet at warp speed!  Some problems with offsets (even though this program isn't using any....).  Brian is working on it.
« Reply #12 on: September 21, 2011, 05:26:55 PM »
HIYA RAY you will also find that Mach will sometimes MOVE the Z at an accelleraton rate so fast it will Trip a 1kw servo on a positionaol error(NO it is NOT a servo problem).
