Hello Guest it is October 18, 2026, 02:03:42 AM
Author Topic: Button Color?  (Read 27815 times)
Re: Button Color?
« Reply #20 on: September 12, 2011, 01:57:18 AM »
Hello,
the message "Image path can only be changed if no setfile is loaded" shows only up when a attempt is made to set or change the "User defined image path" in the "Generic progr settings" dialog.
This field should only be used if multiple bitmap folders for the same set file are used. In that case the bitmaps must be copied by hand to the Mach3\Bitmaps folder.
I don't think many users will need that option.
Klaus
The brain isn't a soap, it doesn't shrink when used.
