Hello Guest it is October 25, 2026, 08:57:17 AM
Author Topic: Something HAS to be wrong with my steps per inch....  (Read 8762 times)
« on: September 05, 2011, 10:08:15 PM »
Hi folks.
Im a total newbie, I'll admit.
Im running a cncrouterparts.com design 80/20 build.
I'm using a Gecko G540, Nema 23 steppers, 5 start 10 tpi leadscews, and of course mach3.
I have seen others using steps per inch at "4000"
200 step motors x 10 microstep drives, x 2 turns per inch on the screws.
But, my steps per is only accurate around "160". Thats right, one-hundred-sixty.
And thats a rough estimate, I havent measured it with any accuracy,
I cant figure out what I'm doing wrong. Any ideas?
Re: Something HAS to be wrong with my steps per inch....
« Reply #1 on: September 05, 2011, 11:29:16 PM »
You're probably running in metric, rather than inch, mode....
« Reply #2 on: September 06, 2011, 06:41:57 PM »
Yep.   Sure was.
Here's where it gets really interesting.
I reset my steps per inch with mach loaded up with no G code.
I had to set it to about 100,000 steps per inch to be in the ballpark of 1 inch.  I knew this wasnt right, but it worked....sort of....The DRO on mach read 1 inch of movement for 1 inch of travel.
Then I loaded my G code, and the steps per inch was no longer accurate.   It changed, with my G code loaded, to where I wanted to be, 4000 steps per inch.
Great, I suppose, but why did my "steps per"   change when the G code loaded?
