Hello Guest it is November 24, 2026, 03:50:06 PM
Author Topic: help need to create mirrored a component  (Read 14902 times)
« on: August 27, 2011, 02:34:55 PM »
hi to all, newbie here, please please help. my problem is that i wish to create left and right handed versions of a program, i already have the 'left hand' proven through and working well, however, i need to have a program that creates the 'right hand', a 'mirrored image/part/component'. i have looked through the help files only to find 'mirror part 10-4' but this does not shed a light on the subject so i am stuck!!!!!! i am using mach3 mill, can anyone assist. many thanks in anticipation Barry
« Last Edit: August 27, 2011, 02:38:28 PM by usermaatresetepenre »
Re: help need to create mirrored a component
« Reply #1 on: August 27, 2011, 02:41:21 PM »
Try scaling the X or Y axis by -1.
« Reply #2 on: August 27, 2011, 02:50:36 PM »
hi hood thanks for the fast comment, do you mean in the prog or in the 'scale' box close to the 'job display' area of the 'program run screen' baz
« Reply #3 on: August 27, 2011, 03:06:01 PM »
scale box at the side, change it to -1 for X and regen toolpath and you will see it mirrored.
« Reply #4 on: August 28, 2011, 04:58:36 AM »
hi hood thanks for your input baz
« Reply #5 on: December 21, 2015, 09:52:49 AM »
Hi, did u ever try it? If yes, please give us a screenshot when it was set on the mach3, thanks...
« Reply #6 on: December 26, 2015, 08:09:10 AM »
I've used -1 scale to mirror parts and it just works, you can mirror any job yourself if you need to see what it looks like.
 - Nick
