Hello Guest it is November 22, 2026, 02:28:01 PM
Author Topic: Zero Radius Arc  (Read 38009 times)
vmax549
Re: Zero Radius Arc
« Reply #10 on: October 12, 2007, 08:50:15 PM »
YOU have to get above 2.48 download the developmental version. WHat version were you running prior to V2.48?
Re: Zero Radius Arc
« Reply #11 on: October 13, 2007, 07:27:09 AM »
It was Mash2.02 lock down version
But I think problem in postprocessor this Visual mill 5 post is very complex 5axis and have some K lines with I have no idea about at mecsoft just dont want to know about as no one complain.
vmax549
Re: Zero Radius Arc
« Reply #12 on: October 13, 2007, 08:07:24 AM »
K is an arc modifier in Z axis similar to I&J for x/Y along with other things in different cycles. Look it up in the manual page 10-9 I believe.
If you were at v2.02 then then the problem I mentioned would not be causing your problem .
I think you need to find a proper postprocessor for your cam program to drive mach correctly. Being complex is not a problem with MACH. It just needs the proper command language to do it correctly.
Re: Zero Radius Arc
« Reply #13 on: October 14, 2007, 06:43:14 AM »
Thanks for help I have resived modified post from Graham and problem was, Mash3 doesnt support helix spiral comands yet with sa I unerstand now this K words neded for Graham chande in postprocessor so helx-spirals came out as arcs it need to be polished G17 G21 G40 G54 G64 G90
(Set MCS)
(Deep Drill )
T1 M6 (12)
G00 Z6.0000 X0.0000 Y0.0000
G83 X0.0000 Y0.0000 Z-11. R2.5 F250.0 Q2.
G80
G00 Z6.0000
(Hole Pocketing)
T2 M6 (3)
Z1.5000 X0.4885 Y-0.0985
G01 Z0.0000 F250.0
G17 G03X0.5000Y0.0000Z-1.4000I0.0000J0.0000
X0.1046Y1.3961I0.0000J0.0000
X-0.1046 Y-1.3961 I0.0000 J0.0000
X0.1046 Y1.3961 I0.0000 J0.0000
G01 X0.4885 Y-0.0985
 G03X0.5000Y0.0000Z-2.8000I0.0000J0.0000
G01 X0.0000 Y0.0000
G00 Z1.5000
M05 M30
it gave an erors Zero radius arc line12,  but looks promising then finished I will send it to Posprocessors Forum.
Many thanks to every one again.
Re: Zero Radius Arc
« Reply #14 on: October 14, 2007, 10:55:46 AM »
Try changing your IJ mode in Mach3 to absolute.
Also, K is also used for arcs in the XZ and YZ planes, G18 and G19.
Re: Zero Radius Arc
« Reply #15 on: October 15, 2007, 02:48:14 PM »
Tryed this And steel same
For some reason Mash doesnt like arks ??
