Hello Guest it is October 06, 2026, 04:43:35 AM
Author Topic: Motor Tuning Problem  (Read 11142 times)
« on: August 16, 2011, 10:54:02 AM »
I need to tune my z axis motor but when I click on Motor Tuning nothing happens. Everything else in config works. Does anybody know what the problem is ?
Re: Motor Tuning Problem
« Reply #1 on: August 16, 2011, 01:17:25 PM »
Is the driver installed properly? If you run the DriverTest.exe what does it say (its in the Mach3 folder)
« Reply #2 on: August 17, 2011, 12:03:28 PM »
The driver test wont work either. Everything else works as it should.
« Reply #3 on: August 17, 2011, 12:24:49 PM »
Can you attach your xml and I will see if there is a config issue.
« Reply #4 on: August 17, 2011, 01:26:03 PM »
Hood, thank you very much forr your help. I just tried the driver test again and inexplicitly  it worked. I then tried Motor Tuning and it worked. Problem Solved, (how?)
« Reply #5 on: August 17, 2011, 01:31:52 PM »
Ok what happened was you did not have the driver installed for some reason, running the driver test will install the driver so next time you started Mach or ran the driver test it would be fine.
