Hello Guest it is November 13, 2026, 09:41:49 AM
Author Topic: max feed rate?  (Read 44308 times)
Re: max feed rate?
« Reply #20 on: December 17, 2006, 09:26:01 PM »
Post your XML and we will see what is going wrong here...
www.newfangledsolutions.com
www.machsupport.com
Re: max feed rate?
« Reply #21 on: December 18, 2006, 06:35:25 AM »
how does one do that. i guess what i mean is where in mach can i find the xml file.
Re: max feed rate?
« Reply #22 on: December 18, 2006, 08:14:38 AM »
Under mach3 there should be a Mach3Mill.xml file. please post that file
www.machsupport.com
Re: max feed rate?
« Reply #23 on: December 20, 2006, 01:47:24 PM »
How fast is your machine. My mill did the exact thing. Jogged just fine, but when I stuck in code it went all wonky at 45khz. I turned down to 35khz and ran perfect. I then changed the PC to a 2.4ghz p4 with 512m ram with a Lava dual PCI port card and it runs perfect at 45khz. My mill (Full size knee mill bit bigger than a Bridgeport) Now does full rapids at 180ipm X and 150 Y and runs the roadrunner file pretty darned fast. Before the new computer/card the fastest rapids I could get were 120 ipm each axis.
My feeling is it is a computer problem, not interference.
Re: max feed rate?
« Reply #24 on: December 20, 2006, 07:55:15 PM »
hmm yeah that may make sense. right now I can only run at 25KHZ and the fastest rapids I can get at that is 75 ipm . I noticed though that if I switch screens in mach while my machine is doing a rapid. my motors make a similar sound for a split second while it is switching. The computor is pretty old. its a windows 98 dell that I inherited so that may be the problem. if I could run at 35 KHZ I think Id be fine but its a nogo with this setup for now.
anybody else agree with this theory.
Re: max feed rate?
« Reply #25 on: December 21, 2006, 06:57:51 AM »
Sounds like the computer is right on the edge of not running mach.. Keep it at 25KHz :)
www.machsupport.com
Re: max feed rate?
« Reply #26 on: December 21, 2006, 04:20:57 PM »
Yep. Get a faster computer.
Heck, I have seen P4s at goodwill!
Or Frys has some pretty good deals on no frills computers.
