Hello
Guest
it is
October 22, 2026, 07:12:09 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
mach 3 driver test program
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: mach 3 driver test program (Read 30872 times)
Carnoustie, Scotland
Re: mach 3 driver test program
Reply #10 on:
August 19, 2011, 07:25:39 AM »
So your problem is you can not set puse width to 2 or 4?
I tried with your xml and its fine, in fact it was actually set to 2 fr pulse width a Dir was zero.
Logged
komar1970
111
Reply #11 on:
August 19, 2011, 07:33:22 AM »
but why does it not shows me 2 only shows me 1
Logged
Reply #12 on:
August 19, 2011, 07:36:38 AM »
please attach a screenshot of what you see as I see as below with your xml
Hoo
Logged
komar1970
111
Reply #13 on:
August 19, 2011, 07:54:20 AM »
i have only thet
Logged
Reply #14 on:
August 19, 2011, 05:45:12 PM »
You xml works for me....maybe its the screen your using.
Try it with the standard 1024 mill screen.
Logged
komar1970
111
Reply #15 on:
August 20, 2011, 08:07:17 PM »
in other computer is other screen and is the same
Logged
Reply #16 on:
August 20, 2011, 08:08:33 PM »
Well I dont know how it can be unless its a different xml you are using than you posted?
Logged
komar1970
111
Reply #17 on:
August 20, 2011, 08:10:22 PM »
no only that
Logged
Reply #18 on:
August 20, 2011, 08:11:35 PM »
well afraid I dont have an answer for you as it works fine for me and also Rich.
Logged
Reply #19 on:
August 20, 2011, 08:13:04 PM »
What version of Mach are you using? May be that there was a problem with that at some point, dont recall ever hearing about such and issue though so only a wild guess.
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
