Hello Guest it is October 21, 2026, 06:08:39 PM
Author Topic: When my CNC router is moving with the G Code it is jerking with each line!!!!  (Read 9526 times)
When my CNC router is moving with the G Code it is jerking with each line!!!! The Constant Velocity button is turned on. I have to slow it down and run the machine about 1/4 of its full capacity. I honestly don't know what else to do. The machine works fine when using 3 axis and we can run it at full speed but as soon as we introduce the A & B axis then we are having to slow it down.... its like mach 3 cant supply enough data fast enough to the machine...
Help i need to get this thing going properly!!!
Try this action, may help...
Diselect the option Config->Toolpath->Tool Position
I have seen jerking movement because of this in the past.
John
