Hello Guest it is October 18, 2026, 07:27:44 AM
Author Topic: Software Limits with G-100 and Jogging V 2.0.022  (Read 17313 times)
« on: December 07, 2006, 01:47:40 AM »
At this time i have no limit switches
Trying to use software limits to keep from crashing
When jogging, Software limits do not work!
is this normal????
Re: Software Limits with G-100 and Jogging V 2.0.022
« Reply #1 on: December 07, 2006, 06:08:51 AM »
I know this is a silly question but, do you have your soft limits enabled? What version are you running. I could do some test on mine.
« Reply #2 on: December 07, 2006, 10:11:55 AM »
Yes soft limits are enabled( if i load roadrunner file i get message about exceeding soft limits)
But when i Jogg it will crash on all 3 axis if i let it jogg that far
I am running Mach3 Version 2.0.022 the latest it also did it in the previous version
On your machine can you jogg past the soft limits?????
« Reply #3 on: December 07, 2006, 12:18:53 PM »
You need to have a point to zero your mill, when you have a home switch you reference to it and that then tells your softlimits what its extents are. You could make a mark at the extreme of one end of each axis, jog to them and make that your reference , your soflimits should then work. You will need to do this each time you start Mach.
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
« Reply #4 on: December 07, 2006, 12:51:37 PM »
Soft limits don't work on the g-100 yet.
Sorry
Chad
« Reply #5 on: December 07, 2006, 01:24:01 PM »
OOPS, should learn to read the title.
« Reply #6 on: December 07, 2006, 04:28:23 PM »
Thankyou that is what i thought,
Well that will give me the incentive
to get the limit switches installed
The unit i am using i got off of ebay
Its an old Sony robot  kind of light weight
So My Crashes are not as destructive as others!
It just keeps adding counts on the DRO
IT is just a testing platform for me to learn Mach3 and CNC Programing
Though it may work ok for a PCB Router????
Thanks for the help everyone
No rush on the softlimits just thought i was missing somthing
