Hello Guest it is November 11, 2026, 11:14:08 PM
Author Topic: mach3 file on my nm200  (Read 7400 times)
« on: July 05, 2011, 10:15:59 AM »
Hi every one great site and  i like mach so simple ( needed for me)
i was woundering if it is posable to copy the mach3 fileand license form my nm200 and install this file into the lathe that i am building up.
the reaseon for asking  it has lathe tool set on it and  i like the set up of it and i can't get the same set up to download from this site.
any and all help is welcomed
thanks
andrewm
Re: mach3 file on my nm200
« Reply #1 on: July 05, 2011, 11:49:51 AM »
You would need to first download and install the file from the website as Mach3 needs to install files into the system folder and such. After you install mach3 however, you could copy the whole Mach3 folder from your nm200 onto the computer running the lathe, just accept the overwrites that will popup and you should be good to go.
We allow you to copy the license file as long as your not using the software to make money, if you are we ask that you buy another license file.
