Hello Guest it is October 20, 2026, 09:44:35 PM
Author Topic: CNC telescope mirror grinder.  (Read 40776 times)
Re: CNC telescope mirror grinder.
« Reply #10 on: December 26, 2006, 09:40:19 PM »
Here's a guy using a Shoptask to cut glass to make lens.
http://home.comcast.net/~cassarole/CuttingGlass.html
If you want to kill time, why not work it to death!
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
« Reply #11 on: December 26, 2006, 09:49:17 PM »
cool good post, thanks!
Chad
« Reply #12 on: February 26, 2007, 05:06:52 PM »
Spherical mirrors for telescopes are not all that hard to make and can be made at home. By hand even! No cnc required. The mirrors are lapped using carborundum or diamond compounds. It can be done faster using a couple of gear motors though. After the mirror is ground you coat it with aluminum using evaporative deposition in a vacuum chamber. Scientific American has had articles in the Amateur Scientist section n the past on these subjects.
The reason they dont want you touching or cleaning the mirror is because the mirror is a first surface mirror where the aluminum reflective layer is deposited on top of the glass not under like a normal mirror. These surfaces are usually not hard coted so even cleaning can scratch or smudge the surface.
