Hello
Guest
it is
November 01, 2026, 10:07:38 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
LazyCam (Beta)
Importing a Cabinet Parts Pro DXF
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Importing a Cabinet Parts Pro DXF (Read 62312 times)
ger21
6,295
Re: Importing a Cabinet Parts Pro DXF
Reply #10 on:
June 23, 2011, 07:42:39 AM »
I think V-Carve Pro is getting confused because the dados are touching. The dadoes need to extend beyond the parts by half the tool diameter, or the dadoes will not be fully cleared.
I'll play with it tonight using a toolpath template. I believe it should work.
If you create a pocket toolpath separately for each dado, it should also work.
Logged
ger21
6,295
Reply #11 on:
June 23, 2011, 04:08:30 PM »
You must be doing something wrong, as it works fine for me.
Logged
bobmagnuson
9
Reply #12 on:
June 23, 2011, 05:45:48 PM »
I don't know there was ever any doubt about that!
What steps did you take to create the tool paths?
Logged
ger21
6,295
Reply #13 on:
June 23, 2011, 06:26:53 PM »
New File
48 x96
Import Vectors - Select the dxf file and it's imported.
Select the dados - Hold the shift key for multiple selections.
Choose the pocket toolpath, select a 1/2" tool, set the depth, choose contour, and OK.
That's it.
Logged
bobmagnuson
9
Reply #14 on:
June 23, 2011, 07:25:41 PM »
Thanks Gerry
Logged
Print
Pages:
1
2
Go Up
« previous
next »
