General CNC Chat > Show"N"Tell ( Your Machines)
How to- USB powered LCD display of DRO`s
cd_edwards:
I think there's a serial version of the gravitech board. As for the USB, it's just a USB-> serial conversion. I really need to upload a new version of the plugin next couple of days.
lajoolaj:
hello, i have a little promblem. i am trying to configure my gravitech lcd trought macropumb. here is code that i am using.
cnt=getVar(1000)
if cnt=10 then
setVar(1000, 0)
SendSerial _
"?x00?y0" & "S " + Format (Getdro(17) , "0000.00") + " " & _
"?x00?y1" & "F " + Format (Getdro(18) , "0000.00") & _
"?x00?y3" & "T " + Format (Getdro(24) , "0000") & _
"?x00?y2" & "C " + Format (Getdro(14) , "00:00:00")
else
setVar(1000, cnt+1)
end if
spindle speed, feedrate and tool number is working fine. but i have problem with elapsed time. on lcd is always "00:00:00". i try to write code without 00:00:00 but then is on lcd only "0".
sorry for my bad english
docrawfo:
I got the kit and display from Gravetech and it is all put together. It works great using a hyperterminal program. It is set up on Com 5 on my PC. I have installed the PlugIn and have started Mach3 and enabled the PlugIn and restarted Mach3. After shutting down, I changed the ComPort from -1 to -5 in the XML file with the Artsoft XML reader. When I run Mach3 again, nothing happens on the display. I shut down Mach3 and go back to the XML file and it is back to -1. Please help!
Don
Wortex_SVK:
Hello is there anyone who try this solution for Mach3 R2.42 and Win7?
Navigation
[0] Message Index
[*] Previous page
Go to full version
