Hello Guest it is November 22, 2026, 06:08:34 PM
Author Topic: 3D probing  (Read 8401 times)
3D probing
« on: June 17, 2011, 01:12:26 PM »
Has anyone tested the 3D-probing with Mach3?
I keep getting "Previous SEQ not yet complete"
What am I doing wrong? ???
Works perfectly in EMC2, but I would rather do it
the Mach3, which compensates for the diameter of the probe tip.
Re: 3D probing
« Reply #1 on: June 17, 2011, 01:55:23 PM »
You do realise that in 3d probing the probe tip diameter is errelivant to  the process.  (;-)
The plugin does not work tight with the lastest versions of mach. you would have to go back to an earlier version so I am told.
