Hello Guest it is November 13, 2026, 05:04:39 PM
Author Topic: how to load liscense  (Read 21870 times)
« on: June 10, 2011, 01:22:19 PM »
Well the long journey is longer..lol..
 I have been working on this project for 3 years..I changed jobs 3 years ago and it requires 100% travel so I have limited time to mess with my mill.
  I bought a BP boss and replaced everything..New steppers, drives, added ac drive,wiring and even paint. : ) I have zero cnc experience.
  I just wanted to learn cnc and think its cool. I have been manual machining for 23 years.I have a nicely equipped shop
  Well, this past winter when I was home and had free time to dig into this and found out my hard drive died..Dooh! I didnt back up anything or record all my mach settings..Double Dooh!
  Fast forward to present..New computer..Got my the settings for motors and pins set..Ready to mess around now. I sent for my wizard license again..I forgot I need to get my Mach 3 license sent also so need to do that.Now to my question...I put the license emailed  to me and put it on a memory stick and then transferred it to my cnc puter.I just put it into the mach folder..I doesnt seem like it works. I am sure I need to do more or will it not work until I get the full mach license installed?  Thanks  Jim
Re: how to load liscense
« Reply #1 on: June 10, 2011, 02:05:59 PM »
I have just tried it and it would seem that you need a registered version of Mach. Contact license@machsupport.com and give them your details and they should be able to look back and send you a new licence.
« Reply #2 on: June 10, 2011, 03:32:47 PM »
If it's seeing the license file, under Help->About you will see your name...or the name it was licensed under.  If you're not seeing that, you could have a corrupt license file.
andrewm
« Reply #3 on: June 10, 2011, 03:40:44 PM »
Make sure the License file is named correctly. Should be Mach1Lic.dat if it has anything after the .dat just rename it to the appropriate file name and it will work.
« Reply #4 on: June 10, 2011, 03:58:57 PM »
He doesnt have the Mach Licence yet, its the NFS one he has.
andrewm
« Reply #5 on: June 10, 2011, 04:01:10 PM »
My mistake, I misread your post. Thought you said you already got both licenses and the Mach3 License wouldn't work.
« Reply #6 on: June 10, 2011, 04:57:07 PM »
 I believe I bought the license from Keling when I bought the steppers and drives. Not sure if I have a proof of purchase..I did find the receipt for the wizards and received it again.
  I sent a note to  license@machsupport.com . Hope they can help.
  On the positive side I got the estop remote button working this time around ! I may even try to get the spindle to be controlled by mach also...I dont know what to do with it then but its fun to put in a wizard and watch the mill do its thing..Better than T.V.!  lol
                     thanks    Jim
« Reply #7 on: June 10, 2011, 04:59:17 PM »
Scott should be able to trace things if you know the name or number the licence was under.
« Reply #8 on: June 14, 2011, 10:25:30 PM »
Well I have the mach license installed but the addons license wont install or work.  I tried several times..When I open mach 3 and click "help" it shows my name in the top box so I guess it is fully licensed. I cant get the wizards to work..If I try to enter a number the box it will change but as soon as I move to another box it changes back to the original set number. Any ideas???  Thanks   Jim
« Reply #9 on: June 15, 2011, 02:02:11 AM »
Are you pressing enter on your keyboard after you type the numbers in the DRO's?
