Hello Guest it is November 24, 2026, 01:19:57 AM
Author Topic: would like help using mach3turn wizard  (Read 22703 times)
« on: June 08, 2011, 09:41:30 PM »
hello
I hope I'm in the right area to ask this question I'm new to forums
i'm trying to turn an involute gear tooth cutter with the turn wizard od turn/od fillet
it makes the right to left fillet perfect but i cannot make the left to right fillet to complete the involute shape
anyone feel like helping a newbie i need to fillet from both directions
thanks steve
« Last Edit: June 11, 2011, 08:06:58 AM by RICH »
Re: would like help using mach3turn wizard
« Reply #1 on: June 11, 2011, 08:20:13 AM »
Can you post a dimensioned sketch of the cutter.
« Reply #2 on: June 11, 2011, 08:40:05 AM »
Not totaly sure what your plans are so here is some info FWIW.
How i made some gear cutting tools for use with a fly cutter.
http://www.machsupport.com/forum/index.php/topic,8118.msg51321.html#msg51321
http://www.machsupport.com/forum/index.php/topic,8120.msg51325.html#msg51325
Art has created a slick program to generate the code to cut gears on the mill. It is called Gearotic Motion......it's a slick program.
Do an internet search for the site.
Somewhere in here  ??? I posted  a spread sheet that calculates the dimensions for drawing any gear in CAD.
So what one can do is select a gear and comparitively find the nearest matching radius to make one....great trick for making small gear cutters.
« Last Edit: June 11, 2011, 08:45:18 AM by RICH »
« Reply #3 on: June 11, 2011, 04:13:19 PM »
hi rich
thank you for your reply
here is a post i found to make a form cutter for the lathe, I was trying to get the fillet wizard to cut the radius's on the shaft. it cuts the right side as your facing it fine but I cannot cut a radius on the left side.
« Reply #4 on: June 11, 2011, 04:14:04 PM »
The txt doc opens in wordpad
« Reply #5 on: June 11, 2011, 04:17:49 PM »
the tool then will be milled and relieved to work like a hob but with just one row of teeth
« Reply #6 on: June 11, 2011, 04:34:19 PM »
I have just started with cnc and I know no g-code I'm using wizards to start with some really good results. I can make this by making the cut in the middle of a longer shaft doing one side then inverting it in the collet and finishing but I would like a way to cut the radius on the left side without removing the shaft from the collet I purchaced both mach and new fangled products I dont know where to update  I'm new to forums also so I get
lost easy
thanks for any help
ps nice job on your fly cutters that looked like it worked well too I did them by hand under a magnifyer  worked ok
this Idea I have should produce a full set of cutters for however many teeth that will last a long time
« Reply #7 on: June 11, 2011, 05:36:42 PM »
Why not do the forming as shown in the article?
You can generate the code using LazyTurn but you will need to have a dxf file with the profile.
Looking at the turn wizards, seems they only provide for turning the radius on the tail side of the piece.
« Reply #8 on: June 11, 2011, 05:46:13 PM »
the article would require a tool for every range to be made myway would be so easy i'm off to find a user wizard that will cut a radius from both directions someone else has to have had this come up.
thanks for your fast reply you guys in here are great
I guess I'm going to have to learn lazyturn too   ....
good thing this is a hobby they would be cutting my pay if this was my living lol
thanks again
steve
« Reply #9 on: June 12, 2011, 04:40:07 AM »
All the Turn wizards that i am aware are listed in the following thread:
http://www.machsupport.com/forum/index.php/topic,17103.msg116309.html#msg116309
Wizard 2 & 16 in the pic Flyout Modified HCIR would probably do the trick but they are modified wizards that need to be tested.
I didn't do the mods and not sure just how far the mods went: ie; they post comments, work in radius and diameter mode, some are new, etc.
If you find something let us know,
