Hello Guest it is November 23, 2026, 02:34:33 PM
Author Topic: OEM Code for alternating .set and .sset screen  (Read 15979 times)
« on: June 07, 2011, 08:40:37 AM »
I'm just working on a panel for my mill using a modbus device. Now how do I switch between .set and .sset screens?
« Last Edit: June 07, 2011, 08:55:36 AM by acieradave »
Re: OEM Code for alternating .set and .sset screen
« Reply #1 on: June 07, 2011, 01:38:15 PM »
Not really sure what you mean, can you clarify a bit? Are you wanting to have a button on screen to change instantly to a simplified screenset? Seem to remember that could be done in Mach2 days but not seen it for a long time.
« Reply #2 on: June 07, 2011, 01:47:09 PM »
Try OemButton(232)
Offline Greolt
  •  956 956
« Reply #3 on: June 07, 2011, 03:20:50 PM »
I use the sset format with my screens all the time with the following,
ToggleScreens()
There is some info here,
http://www.machsupport.com/MachCustomizeWiki/index.php?title=Mach_specific_Subroutines/Functions_grouped_by_purpose
However I think I'll try the Button code number that TP pointed to.  Thanks TP.
Greg
« Reply #4 on: June 07, 2011, 03:42:34 PM »
I forgot all about togglescreens()
Has anyone put together a new manual on dros leds buttons commands yet ?? I know we have the XLS version on some of these.
Maybe combine the VB manual with the OEM stuff into one. ????
Any Manual writers out there needing something to do? (;-)
« Reply #5 on: June 08, 2011, 02:37:08 AM »
Thank you all
OEMcode 232 does the trick just fine!
Greets
  •  9,378 9,378
« Reply #6 on: June 08, 2011, 02:45:50 AM »
Excellent suggestion Terry but it really needs someone with knowledge of VB etc. such as yourself.  ;)
« Reply #7 on: June 08, 2011, 05:32:04 PM »
Terry,
I added the OEM codes to the programmer's manual about the first of the year - see
http://machsupport.com/docs/Mach3_V3.x_Macro_Prog_Ref.pdf
See section titled "OEM Series Button, DRO and LED numbers" - its the last section of the manual.
It has all the things in the prior spread sheets (to the best of my knowledge).
FYI - it's really Mach's doc, but I have the source and add things when I find out about them, then I send an updated doc to Brian.
Author of the MachStdMill Extensions for Mach3
www.CalypsoVentures.com
« Reply #8 on: June 08, 2011, 06:06:38 PM »
COOL DAVE I will check it out. I have a OEM BOOK that I made up for dros leds.etc I exported the sorted info out of the XLS 2 different ways.
1 way is sorted by TYPE then # (1-300)  and gives the descripttion.
2 way is by TYPE then Description (a-z)
THat way you can look for a function either way.
The book is about 64 pages long doubles spaced so us old guys can read it. (;-)
If anyone wants a copy I can post it in the Mach ToolBox.
TWEAKIE If I wrote the manual you would be so confused you would migrate to EMC in self defense. DAVE is the VB master(;-)
